This is my first post on here, and yes I did try searching first.
My 12v DC outlet doesn't work, I've had the cover closed for the last week and finally decided that my radar detector is necessary to keep my foot in check!
Well, there is no power. I searched through both of the fuse panels that I could locate and didn't see anything that stood out, then again, I didn't pull any fuses yet. I tested using my fluke clamp meter (I'm an electrician) and I've got nothing, power or continuity. Anyone have the shop manual?
Also I tested the 120v receptacle in the trunk. It's wired backwards, hot and neutral are switched. I did this using a simple GFCI plug tester with lights. I'll be having the dealer fix this because I don't feel like tearing the plastic apart quite yet on this rig.
This is an earth color Overtrail Plus FYI. I'll report back if I find the fuse location.
