I was wondering for emergency use only, if you had to use the 33” spare you could air down the 35’s to 20 psi and air up the 33 to 50psi and disable the limited slip function? Therefore, decreasing the circumference difference and get you home without damaging the drivetrain? You know if you’re driving a big circle the drivetrain compensates for the different speeds of the outer tires.A question for those that have increased tire circumference while leaving the factory spare. Being the rear and center differentials are locking, I assume the rear does not have any type of limited slip. Is anyone concerned about running a different tire circumference if and when you have a flat tire? I would assume at the very least the vehicle would throw a couple of codes due to prolonged wheel speed differences.
