AW Tires for Premium Plus
longshot53
4
North Carolina
Just acquired a Premium Plus. There's a lot of helpful discussion here about aftermarket tires AND wheels, but I'm just considering changing out the OEM all-season Yokohama Geolander tires for something all-weather. Need advice.
1. I live in moderate climate that does have snow/ice 4-5 times a year that I must drive in along with lots of rain. Do occasional off-roading. Would AW tires be an improvement over the OEM tires? Or should I just stick with what I have and put my $$$ elsewhere?
2. Would AW tires—as opposed to the OEM tires—either affect the smoothness of the ride or lower my gas mileage?
3. If I change to AW tires, should I get the same size as the OEM tires, or can I go wider? While I'm not a big fan of the OEM wheels on the Premium Plus, I do not want to spend the extra $$$ for new wheels.
4. If AW tires might be better for me, which ones would you recommend? (I've heard Falken Wildpeak AT4W, Nitto GE Terra Grappler, and Bridgestone AT Ascents).
Many thanks for your advice!
If you are not doing heavy offroading or not trying to improve the looks...AW tires are not necessary. The stock tires will work on everything...Including dirt and snow...lol.
AW tires will add more noise and lower mileage. you can safely go to a 275 width on the stock rim (each tire has their own limitation of allowable rim widths.
  • Sit up
  • Pay more attention (driver inattention detected)
  • I heeded the warning and corrected my seating position
  • I disabled the driver warning alerts
  • Look forward
