Has anyone opted for the catback exhaust option
Just wondering about turning off the augmented sounds. Is that setting in the system setting menu? I’ve done that on an RX but haven’t come across this in the GX. Thanks.I installed MF and have no vibration issues. They could have installed the over axle pipe where it’s touching a crossmember. It’s very close and needs adjusted as you tighten the clamps. I also would not install this without turning off the augmented sound! When I turned that off, I found most of the weird engine noises I thought I was experiencing were just the ML processor trying to keep up with what the actual engine was doing. I thought I had a takeoff hitch but it was just noise and not the actual engine.
No dealer or CaristaJust wondering about turning off the augmented sounds. Is that setting in the system setting menu? I’ve done that on an RX but haven’t come across this in the GX. Thanks.
