Gas Gauge hack using OBD2
tiiBimmer
10
16
Exton, PA
Like a lot owners, I found the lack of warning for low fuel and the small gauge in the cluster to be a little frustrating.
I was able to find a solution to this problem that works great.
I purchased a bluetooth OBD2 adapter called vLink MC+ for under $60 and use an app called SideCar that works with CarPlay to put a gas gauge on my CarPlay interface. The only drawback is that you need to use the SideCar app all the time (with Apple Maps integrated) to have the gas gauge displayed, but I like it.
Here is a link to the OBD2 adapter
Amazon.com
Here is a link to the SideCar app
apps.apple.com
‎Sidecar: Automotive assistant
‎Your personal automative assistant. A powerful OBD scanner with integrated CarPlay widgets, Shortcuts, and iCloud sync support. Now includes turn-by-turn navigation in CarPlay. Want to beta test Sidecar and get two months free? Visit Beta tester handbook - Sidecar to learn more...
apps.apple.com
apps.apple.com
Hope this helps someone else!
    Votes: 12 35.3%
    Votes: 12 35.3%
    Votes: 10 29.4%
