instrument cluster height adjustment
Pap
New jersey
My dealer showed me how adjust the height on the instrument cluster. So he showed how to adjust it up and down in relation to your seating height. I can't for the life of me find that adjustment anywhere now. I looked in the manual as well. I need to adjust it up as the steering wheel is cutting off the view of the lower portion of the cluster. Any help would be great!
Edit- the instrument cluster isn't being cut off by the steering wheel as it is by the eye monitor above the steering column.
I'm not referring to the HUD. I'm looking into adjusting the height of the instrument cluster above the steering wheel column.
They adjusted the cluster so the eye monitor didn't intrude on it.
Are you sure they didn’t adjust the steering wheel so that it didn’t block your view? I moved mine after I adjusted my seat height.
sounds like you just need to tilt down your steering wheel. The eye monitor is part of the steering column housing
