Lexus OEM GX550 crossbars
Can the GX550 OEM crossbars be moved or adjusted?
Yes they can be removed.
The vehicle should have come with a tool to help remove them…it’s just a fancy allen key. They are in a fixed spot though on the rack rails.
Remember to make note of the orientation of them if removed and position. If not facing or in the right spot they won’t fit properly.
I don't want to remove them; just wondering if they can move forward or back. It's a premium plus. Putting a Thule box on top fro a trip from the east coast to Utah.
Weird
Mine only has the 4 tapped holes on the inside of the rails for the cross bars to be threaded into
Remove end caps, loosen with Allen, slide to where you want, tighten back down, replace cap.
