Titan7 AK2 with Falken Wildpeak A/T4W LT285/70R18 (Does not fit stock suspension)
Land Bully
0
Indiana
I mean it fits, but it just barely rubs on the safety frame when turning.
The GX550 Center Bore / Hub Bore is 95.1 mm, so I ended up buying some hub centric rings from Amazon. And the stock lugnuts are super short, so I ordered some extended lugnuts. As many of you already know, it's a common complaint for aftermarket wheels. I was only able to get thread engagement on about 12mm. I'll be installing the extended lug studs soon.
Size: 18" x 8.5"
Offset: +20mm
Bolt Pattern: 6 x 139.7mm(5.5")
Center Bore: 106.3mm
LT285/70R18
