Washer fluid not pumping out
UpNorthGX550
5
Duluth,MN
Having an issue with our OT+. Washer fluid is not pumping out on the front or back windows nor the headlights. I can hear the pump but no fluid comes out. Easy fix or do I need to head to the dealer?
Thanks
I was worried when we bought ours here in TX and were driving home for the holidays that they may not be the washer fluid with the "anti-freeze" additive we were used to from PA. I'm sure you checked, but any chance it's frozen?
I noticed that mine has terrible spray jet patterns! It jets 75% of the fluid to the top of the window and nothing lower than half way down. I'll be having the dealer look at it when I have them fix my rear power outlet that's wired backwards and 12v cig outlet that doesn't work.
The original washer fluid that came with our GX550 was not rated for below freezing temperatures. Ask me how I know.. it worked at 20+F so I thought good to go but we had a day below zero and it froze. Replaced with a winter fluid and it works.
  • Yokohama Geolandar 275/60 R20
  • Dunlop Grandtrek 275/60 R20
  • Other
