I'm leaning towards the Prinsu RR and a Westcott leveling kit. Two of my good friends both have Prinsu and have been really happy with them...on a TACO and a 4Runner.
When I look at all 3 of the racks mentioned above - I noticed that the front corners have a weird gap on that part of the roof line that I really do not like - anyone see this or is it just the pictures.
me either - I hope it is just a camera angle - but I do not think soNow I can't unsee that
Is that your rack?Now I can't unsee that
The greenlane RR appears to be set back a couple inches though and has a corner cut.
Is that your rack?
How did the install go with the EPDM rubber washers? Did you put silicone on the bottom of them? Curious where you got them/what they look like. ThanksThe Westcott is the lowest profile which means less wind noise. It was one of the first to market and many have it reporting no noise.
Prinsu is about 2” taller and basically the same design with the few detailed differences described above (drop in t rails, side pieces are reenforced)… that don’t warrant the price difference to me.
The Sherpa looks structurally the same as the Prinsu, however it mounts using the cross bars vs the side frames. I’m not sure if that’s the strongest design.
I do like the sherpas “booting” systems for keeping water out.
It’s also the gaudiest design competitive with the victory4x4 from my view.
I think the Westcott is the superior design and best price. I’ve got mine assembled and will install in a few weeks.
I’ve made a few tweaks (pics to follow) preparing for install as I wait for roof PPF.
I used brass washers for the crossbars mount bolts- (the brass will contrast and patina and look sharp against the earth paint).
I also ordered a box of epdm rubber 1/8 washers to sandwich between roof spacers and mounts to seal it.
You should use silicone in any circumstance for added water penetration security. My 17 Taco was victim of the roof tail light leak and rusted all my tools behind the seat and molded the truck a bit. Still stinks. Pissed.
Good point, I'm curious on mount points as well for mounting shovels, awnings, etc. their awning bracket online looks like it would interfere with a Roof Top Tent, thoughts? What are folks using for mounts?About to pull the trigger on a Westcott. But had a question I'm hoping someone can help.
I have an ARB awning and wondering if the Prinsu mounts would work with the Westcott. That's the one drawback with Westcott is they don't have any options for this.
