“Clunk” sound from front driver side - overtrail
gnantt
California
Today when I was removing the skid plate and changing oil for the overtrail, I noticed one metal frame piece was rubbing against the skid plate bolt at the front driver side and making a “clunk” sound. The issue was the hole on the metal frame piece was not aligned with the skid plate bolt hole. I loosened the metal frame and re-aligned the hole.
I do occasionally hear a “clunk” sound from the front of the car when accelerating from a stop. I wonder if this was the source of the sound. Would need few days to confirm if the sound disappears.
  • IMG_9052.mov
    6 MB
If you determine it’s not what you thought, perhaps check your driveshaft. I had clunk noises and discovered that it wasn’t properly libricated from the factory. There’s a grease fitting on the bottom of the driveshaft that is easy to add grease.
    Votes: 9 34.6%
    Votes: 10 38.5%
    Votes: 7 26.9%
