Interesting review of ourr engine´s issuuee...
Still really worrriieed aboout this...
The base Lexus powertrain warranty is "...72 months or 70,000 miles, whichever occurs first."Owners should be worried. This V35A engine issue is likely far from over.
ENGINE
Cylinder block and head and all internal parts, timing belt and cover, flywheel, oil pan, water pump, fuel pump, engine mounts, engine control computer, seals and gaskets
Personally, I’m not worried. I could see how some could be, though, because they don’t want to deal with the headache or be turned off by the idea of an engine replacement.The base Lexus powertrain warranty is "...72 months or 70,000 miles, whichever occurs first."
Reference: Lexus Warranty | Lexus.com
The above is before any extended warranty coverage. With that kind of coverage, it's worth bluntly asking what exactly should owners be worried about?
Agree, that engine has it bad.I just watched this video yesterday. There was debris everywhere in that engine. It spun crankshaft bearings!
don't sawzall, you'll send metal into the filter, get a cheap oil filter cutterWhat’s the best or recommended way to cut or pop open my oil filter? What do you forum members recommend to do that?
I’m willing to sawzall into my next old filter; if so..which direction (orientation) should I cut?
Thanks for any tech assistance..advice.
DJ
Just when I thought I could make it a week without an Amazon order . . .don't sawzall, you'll send metal into the filter, get a cheap oil filter cutter
That's what the filter is forDoes anyone know anything about putting a magnet inside the oil filter to attract larger pieces of debris?
I don't know anything more than any other auto hobbyist/enthusiast/DIY-er/weekend shade-tree mechanic.Does anyone know anything about putting a magnet inside the oil filter to attract larger pieces of debris?
Yes, he is agreeing with Toyota. At 28:14 he says "Yes, I would say Toyota called that right, this motor is full of debris..."Seems like Dave is agreeing with Toyota that it was a debris cleaning issue, not a problem related to main bearing design. Not saying the main bearing design couldnt be better, but that the leftover debris caused the problem.
This gives me relief as a 26 owner because it was caught and announced in 24/25. I would think they implemented the debris clearing step improvement in 25.
Some folks here are worried this is going to be a continuous problem and I’m missing something.
