what mpg is showing on your Dash? Mileage remaining shown will vary based on your current mpg....But as stated above...you will likely get a fuel light when you have used around 17 -18 gal of gas.My gas gauge shows I have 40 miles to empty so I stop and fill up and It only takes 11-12 gallons and the tank is full?? Anyone else have this issue?
So I’m reading that the mileage to empty is really miles left to 16.9 gallons then you go into reserves, last 4 gallons or so. That makes sense because Ive only ever been able to put 12 gallons of gas in to fill it up. Im going to go past that “miles to empty” number and see if I can actually get closer to putting 17 gallons of gas in the tank.what mpg is showing on your Dash? Mileage remaining shown will vary based on your current mpg....But as stated above...you will likely get a fuel light when you have used around 17 -18 gal of gas.
