Check out this video here. Westcott preload collar lift kit with 17" +35 offset. I just placed an order for their lift kit. Now I need to find some +35 offset wheels.
Pucks and shock extenders. I wonder how much worse it’s going to make the ride. You’re going to lose some degree of articulation. You are ok with cutting up your new vehicle? I get it’s for the look and it does look really cool, but if you are seeking more performance off road, this isn’t it.
What I would be interested in seeing is you doing the mod though. And if you can provide any data since Wescott doesn’t have any numbers listed. Thanks
From Wheel Tec: 20x9 / +20mm offset Fuel Flex wheels with BFG 275/55/20 tires (KO2/KO3?) - Stock suspension
I want to put these evo corse wheels on my new GX premium plus. They are 17x8. My question is has anyone had issues with 17's and the brakes? Also I believe the stock wheels are 7.5 and these are 8 so will I have alot of poke? These are a +47 offset, does anyone know the offset of the stock wheels. I really don't want poke haha
View attachment 1230View attachment 1231
You should be fine. Stock is +50.
I ran evo corse wheels on my. 200series in 18s... You can have them custom built to fit just like you want. Just an FYI they are heavy wheels.
Does anyone have suggestions on what rims and tires they would recommend to replace the 22” OEM setup on the Luxury? Looking for something to provide a better ride. Thanks!
Did you end up swapping out your 22"'s? I'm considering doing the same for a smoother ride quality and curious to see if it's worth it going to 18" or 20"? Lux + with the 22's is a bit to spicy for my every day driving.
