Radar Detector Mirror Tap OT+ Issue
Wepa527
New York
Hi Y’all,
I’m trying to tap the mirror fuse to power on my radar detector, only problem is the radar detector won’t turn off when I power off the vehicle and exit.
I tapped the red wire in the center where you would plug in the dongar cable and use the black/white as the ground.
Anyone come across this issue?
Hey I was wondering if you had a finalized picture of your entire setup? Planning on adding my Uniden R8 when I get my car.
Here’s mine tapping that same location. I previously had a mirror mount but it got busy in that area because of the FITCAMX camera
Does anyone know if there is any constant power wires in there? I bought the FITMAX hard wire kit and it would be nice to connect that additional wire somewhere in there.
Look at first post of this thread. The OP originally wired his as constant power.
Planning on maybe tapping my dash cam and radar but I need to do some amperage calculations. Has anyone already done this?
Be careful there. You are tapping either a 5 or 10 amp circuit. Your radar and dashcam need 2 amps. You need an inline fuse at 2 amps. I got this on Amazon and there is enough wire to add a fuse inline. It also wires BOTH the radar and dashcam. Linked here:
