Fuse for High Beams?
Techpoke
12
9
Wilson, WY
I'm installing a Trigger 4 Plus for some light bars. I would like them only turn on when I've activated my own high beams on the headlights. This will ensure that, when an approaching car tells my Lexus to switch from High Beam to Low Beam, my light bars will automatically turn off.
I need to find the fuse that controls the high beams, so that I can put a "fuse tap" on that fuse. This does not draw power from the fuse, it only tells the Trigger when to turn on or off. (BTW, this also means that the Trigger will turn off when the car is not running, which will eliminate any drain on the battery.)
Does any know where this fuse is? I've attached the diagram on the underside of the fuse box under the hood, but do not know how to translate all of the abbreviations. Or could this fuse be in a different fuse box elsewhere in the car?
Look for designation as follows:
(H-LP LH-HI) Headlight high beam (left)
(H-LP RH-HI) Headlight high beam (right)
They should be 15-amp mini fuses.
Hope this helps!
I don’t see it on that fuse panel. I’ve attached the diagram. Am I missing something? Are there other fuse panels in the car besides those 2?
The diagram above (IMG_4492.jpeg) is from the fuse box in the in the front passenger seat footwell.
My diagram to start this thread (IMG_4486.jpeg) is from the starboard-side fuse box under the hood, adjacent to the battery.
The diagrams attached to this post are from the port-side box.
I still cannot find any fuse with the labels you mentioned above. The closest is H-LP CLN, which I assume is for the spray washers for the headlights.
Any other suggestions?
Meanwhile, THANK YOU for taking your valuable time to lend me a hand. I am grateful.
