Correct, it happens after making a left turn from say a stop light. Not the "soft" position you would use to change lanes.do you mean after making the turn it doesn't stop flashing? I don't have that problem... it is a two stage turn signal meaning if you very lightly toggle the signal it was flash for a couple times and stop. if you hard toggle it was stay on until you finish the turn... I had trouble discerning the two at first because the pressure difference between the two is small.
