I noticed that when HOLD button is activated and come to a stop, like a drive thru, I hear a chain clinging-like sound.. seems under the hood
How do you get your hold feature to stay on? Mine turns off when I turn the car off. It's a great feature, but I don't know how to turn it on permanently.I use the feature all of the time. I don't ever hear a noise of any kind. Sounds like a good question for the dealer.
I'm not Kirt but you can't have it stay on between starts. You just get into the routine of starting the car and pushing the Hold button. I do wish it would stay on permanently but that's not something Lexus does.How do you get your hold feature to stay on? Mine turns off when I turn the car off. It's a great feature, but I don't know how to turn it on permanently.
If the Hold button is pressed you'll see a "Hold" in the lower right of the dash. When you come to a complete stop, after about 2 seconds, the auto hold engages (you can see a notification in the lower right of the dash that it has engaged). Then you can take your foot off the brake pedal and the brakes will remain applied until you press the accelerator pedal.What does this feature do?
It’s not the chain on the spare tire because I tried looking at it, the sound seems to be coming under the hood , engine…I use mine all the time too and also haven't heard a noise. Any chance that it's the spare tire chain hitting the spare wheel? If you're at a drive through there's a chance you have your window rolled down and hear it? Easy test is to use some gaffers/duct tape to tape the chain that hangs down off the middle of the spare to the actual wheel and then drive it and see.
