Navigation home and work address
munkeeboi
74
26
Los Angeles
I can't seem to input a home and work address via the car or through the lexus app. I understand that most people don't like putting their home address, but that is not the point here.
On the Lexus app, I can get to "set home address" but it won't allow me to search for my home or work address.
Has anyone successfully added a home or work address through the app or car?
On the home screen of the Lexus app, tap "Find" in the lower right corner. The tap "Destinations". You should be able to set Home, Work, and other favorites. Then for each one tap "Send to Car"
I spoke to a Lexus "Connected Tech" service person but she couldn't figure it out either. I have a reference number and she was supposed to look deeper into the issue.
Set up the addresses on your phone app.
I got to the “set up” for home or work but when I go to search for an address nothing happens.
try waiting on the app for a bit and see if it shows up? happened to me as well but it’s random, sometimes, I had to wait for 20-30s on the Lexus app or nav display before home or fav show up. I am just going to stick with CarPlay . With the new nav setup, I don’t think the maps are stored locally in the computer .. I could not get the factory navigation to work when travelling in areas with poor cell phone coverage up in mountain regions of Vermont and New Hampshire . I much prefer the older Lexus nav system.. I could load navigation and maps even in remote locations..
I got my GX last week and was working on setting this up on my iPhone. As noted already, searching for addresses in the iOS app does absolutely nothing. If you try to search for a business, you’ll likely have luck. Unfortunately, that doesn’t work for home or many other addresses. I tried this on my phone (16 Pro Max) and two iPads. All on some form of iOS 18. Nothing.
I do have a secondary Android phone (Pixel 8 Pro), and the search function in the Lexus app here works perfectly. This may explain why some have issue and some don’t.
Hopefully Lexus updates their iOS app to actually work for this function soon.
what i was abe to finally do (On IOS Lexus App) was in your history of addresses you looked up, you can select one and save it as a favorite...at that point you can select it as your home or work address.
The solution is counterintuitive… On your iPhone, go to settings and then privacy and security, then location services. and then scroll down to the Lexus app. Turn off location services… Set it to “never.“ And then it magically begins to work.
That’s hilarious. I had mine set to always since having it as “while using app” had a persistent location live activity displaying on my iPhone and it was super annoying, changing to always removes that.
Oddly enough, I also have the Android version of the app set to always and search works perfectly there.
Lexus obviously needs to do a little work on their iOS app.
