I’ve tried a few of these but I haven’t found one that works yet. My chains are pretty thick.Would something lIke this work? I've had to use these on tight access vehicles in the past.
are you using an onboard air system? if so, im curious to where you put it.This took care of my 2.5 inch sag. Only need to put 10 psi in these which rides nice. it also lifts the rear 3 inches at the push of a button.View attachment 4491
That’s exactly what I would do, decent set of rear air bags!This took care of my 2.5 inch sag. Only need to put 10 psi in these which rides nice. it also lifts the rear 3 inches at the push of a button.View attachment 4491
I added these to make it easier to chain up. Highly recommended.I’ve tried a few of these but I haven’t found one that works yet. My chains are pretty thick.
Love your solution here. Have a couple of questions. Does the Firestone (blue) airbag support weight or just expands against the spring coils effectively increasing the spring rate? Is the Airlift bag the one that allows you to take care of the 2.5 " sag? Or is it both bags? TIA!This took care of my 2.5 inch sag. Only need to put 10 psi in these which rides nice. it also lifts the rear 3 inches at the push of a button.View attachment 4491
