Cables!
Interesting.
All of your technical expertise and experience aside, there is also the possibility that Lexus calls for “premium” fuel for the GX550 simply because they have a reputation to uphold as a premium vehicle. How could a well-off gentlemen or lady pull up to a gas pump in a vehicle of this caliber and use regular old peasant fuel?
I think we’d all be very interested in a tune that provides more overall HP & torque while burning regular fuel, provided it is 100% completely safe for the vehicle. I think the latter is our highest priority, as opposed to saving a few bucks on gas.
I had the same question. Here was the replyHello,
Does this tune work with a GX that has been modified with the Afe intakes and turbo inlet pipes?
The tunes should be fine however in very very low temperatures we can seen where it can cause airflow related limp modes with aftermarket intakes (on tundras, but I suspect the same for the GX). We are talking temperatures below -20.
I see, thank you for the reply!I had the same question. Here was the reply
It's hard to say for sure, other than the calibration doesn't really reflect the "need" to use premium.
For example the lexus LS500 has this same exact engine and puts down nearly 70 more horsepower, and actually needs premium.
The GX550 is just a watered down Tundra tune with a very small increase in boost pressure at low rpm.
It would make sense that the GX550 requires premium fuel in order to keep up with the brand image.
However....Toyota doing the same thing too.
The Land Cruiser 2.4L Hybrid requires premium fuel.
The 4Runner 2.4L Hybrid requires 87 octane fuel.
The Tacoma 2.4L Hybrid requires 87 octane fuel.
The differences in tunes are...minimal.
It seems to align with the idea that "premium fuel = "higher class of a car"
All pending kits have shipped! Thank you everyone.
GX550 CAN connect install instructions will be on our website under "resources" near the Tundra CAN Connect instructions tomorrow.
We sincerely, sincerely appreciate that you guys were so patient with us getting all these kits out.
Pending tune packs will be distributing tomorrow as well.
Finally, VF Tuner will have shipping closed from the 24th - 28th. (will not affect anyone who has already ordered as your kit is already with UPS).
Thank you everyone!
This is very helpful! How did you disconnect the CAN connector from the white clip that holds it to the metal? I lifted the tab and the entire end of the connectore fell off, but the CAN is stil connected to the white clip. I also wish this was included in the instructions.The CAN connect for my gx550: hope this helps
View attachment 9552View attachment 9553View attachment 9554
The vehicle’s CAN connector has a black cap that is secured to the frame using the white plastic clip. Since there is limited room to work with, I left everything intact to allow the white clip to hold the CAN connector firm in place. I then bent up the small tab that holds the connector to the cap using a long flat head screwdriver. Once the tab is bent, you can then pry out the white clip and pull on the black cap (with the white clip) to disconnect it from the harness side connector. Attaching the VF’s CAN cable to the vehicle’s connector also requires some finessing. I secured the Wiflash to the area with a zip tie and ran the usb cable down to footwell where it is tucked away.This is very helpful! How did you disconnect the CAN connector from the white clip that holds it to the metal? I lifted the tab and the entire end of the connectore fell off, but the CAN is stil connected to the white clip. I also wish this was included in the instructions.
