Has anybody figured out a way to run yellow fogs without using a vinyl overlay? PFA
bingoThere is no bulb spec in the manual.....I have a feeling it is LED and is not swappable.
Nice. What did you go with? I’ve looked around and no luck. Have any pics with them off?Definitely doable…you didn’t dig enough
They are LEDs…not an overlaySo did you replace the bulb or did you use an overlay from Lumix?. I just ordered one
Nice. What did you go with? I’ve looked around and no luck. Got any pics with them off?
Do you have pic installed with lights off? Is housing yellow or no?View attachment 5399
View attachment 5400View attachment 5401
Top LED are the new ones, bottom are OEM
Housing is not yellowDo you have pic installed with lights off? Is housing yellow or no?
Not hard at allNice Job, How was the install?
Thank you very muchProbably an L1B LED like most other Toyota models.
GRC will use either Hyuga Yellow LED or IPF from RHDJapan
TF1 2x LED Fog Light Bulbs 3000K Amber 6000K White 30W Plug and Play Compatible with 2020~ Corolla Cross, Corolla, CHR, SIENTA, RAV4, HILUX HYUGA (Pack of 2)
30W SUPER BRIGHT - Replacement Lights for Fog Light( 8x BRIGHTNESS INPROVEMENT) LED Chip 7545 High Power LED Color White / Amber Application Fog Light Sales Unit 2 pcs a pack Power 30W Lumen 3000 LM (Original: 360lm) Warranty 12 months FIT MODEL: ✅Toyota Corolla CROSS 2020~ ✅Lexus NX 2020~...www.paledbulb.comIPF LED Fog Lamp Bulb X3 - L1B 2600K Deep Yellow - RHDJapan
IPF LED Fog Lamp Bulb X3 - L1B 2600K Deep Yellow. Buy direct with global shipping to your door from Osaka, Japan. We speak English and all email queries are responded to promptly!www.rhdjapan.com
So you had to remove bumper to do this? Thought they’d sit directly behind front fender linerNot hard at all
Just had to figure out what to take off under the bumper and what screws/push pins to remove from the fender liner to pull it back and expose the lights
What the guy replied to you under your postSo you had to remove bumper to do this? Thought they’d sit directly behind front fender liner
correctdoesn’t sound like he removed the bumper. Probably just a combo of front fender liner and the front plastic piece under the bumper
