Yellow Fogs?
incognito.gx
212
152
USA
Has anybody figured out a way to run yellow fogs without using a vinyl overlay? PFA
Probably an L1B LED like most other Toyota models.
GRC will use either Hyuga Yellow LED or IPF from RHDJapan
Thank you very much
Not hard at all
Just had to figure out what to take off under the bumper and what screws/push pins to remove from the fender liner to pull it back and expose the lights
So you had to remove bumper to do this? Thought they’d sit directly behind front fender liner
What the guy replied to you under your post
There are screws holding the plastic trim piece under the bumper and that piece has to be removed to expose the screws needed to be removed that hold the underside of the fender liner so it can be pulled back
doesn’t sound like he removed the bumper. Probably just a combo of front fender liner and the front plastic piece under the bumper
correct
