GX550 Overtrail Vibration
Again it seems like a friction issue that shows up with speed. parking brake dragging or a sensor on the brakes coming on when it should not. Since some folks seem to have fixed it with a brake mechanical maybe the tech could check those?
Not the case for mine. As noted a few times in here, there are possibly two to three different issues being experienced on this thread.
Update on my case….
Lexus put a set of 20” wheels from a Luxury on my OT. They test drove it and said the vibration went away. They put my 18’s on the Luxy and they felt vibrations in it. So now they are waiting for approval from Toyota/Lexus AU to change the tyres over on my rims to try again. They have offered me an opportunity to test drive my OT with Luxy 20” wheels when I am back for the next attempt to fix it. Personally, I hope it is just the tyres as that is an easy fix. Highly unlikely, but maybe there is a defect in the rims? Maybe it’s a dampening issue? I would like to know the weight difference between the OT 18” combination compared to the Luxy 20” combination. Sometimes it feels like the shocks struggle to dampen small bumps. It’s a similar feeling I got in my 150 Prado when I put some heavy AT’s on it. The shocks struggled with the weight, sometimes feeling like axel tramp.
Purchase date 7/8/24 Vibration/shake since new now 3450 miles
7/15/24 Discount tire Road force toyo - unchanged
7/20/24 Drove with Dealer Tech passenger side worse
Dealer Road Road force toyo - unchanged called Lexus specialist
8/14/24 to 8/26/24 Lexus Specialist
- 2 hours test driving his OT+ then my OT+ with lead dealer tech and myself. Frequency testing in the front seat and back seat. took 8 best toyo tires from both vehicles test drive my OT+ again with Lexus specialist and dealer tech again - unchanged. Lexus tech reset adaptations in computer to see if it improved - unchanged. stated the valving in the OT rear shocks are different than Lux/Prem due to anticipated increased weight allowance for overlanding. Suspects it may be due to Adaptive Shocks but no solution.
Changed toyo tires to Wildpeak AT4 LT - Unchanged...
10/1/24 Unchanged, shaking felt in passenger seat and rear seat mostly, not speed specific, worsens throughout the day all types of asphalt conditions. Attempted to capture on video but iPhone stability image control tends to zero out motion. rigged up a water vessel today to help demonstrate and attached some video.
Fully aware that most don't have this issue and thankful you dont, but for those that do its not practical to even drive. For context I have built and owned dozens of cars including numerous FJ40, FJ60, Tacoma's, 4 runners, GX470's, Ford Super Duty trucks and dozens of tractors/semi's etc etc. (just trying to offer context on the source of the diagnostics only not trying to boast so please understand i've not posted since this thread was on Page 1 trying to have a comprehensive perspective for peoples benefit and help try and narrow this down.) Wescott designs has put on the new King shock/suspension package and curious if they did this to any yet that had the vibration. It took Toyota 2 years to address the Tundra motor. They are dealing with the TX stop sale due to the airbag issue with windows down and now the 23/24 Corolla over brake module issue. My wife daily drives 2020 TRD Pro with 60k miles and just put on the wildpeak AT4's to replace the Nitto's and it drives like butter. I've since parked my GX550 and driving one of my other cars.
This vibration is not related to brake shims or squeaking for those thinking that Sroberts may have been related.
Again i'm just sharing my knowledge of my experience and perspective from research over 3 months. and shout out to TFlyfisher love the graphic!
Update
Today I had my colleague drive along me on the passenger side and observe the tire behavior. We were talking over the phone live. Over a few miles at speeds of 40 on both new smooth pavement and older rougher pavement he indicated it was obvious the right rear tire was bouncing constantly while the right front was smooth as glass.
Looking at the part numbers on lexus parts online for the OT, Luxury, and Premium, they are all different part numbers for the AVS shocks. This leads me to believe the valving is all different in the town tube shocks. The drive mode in directs the ECU to change the ride mode in the AVS shocks from comfort, normal sport, etc.
Based on this information it is my belief that one or all of the following may be causing the bouncing.
Programming is set wrong
Faulty valving in the rear shock(s)
Aggressive valving in the OT for heavier over landing loads causing shock stiffness when roads are not demanding longer travel stroke.
Would love to try sourcing oem rear shocks from the luxury or premium trims to experiment ($571 new) or unplugging the rear electrical connection or just waiting for more aftermarket suspension options available (king, icon, etc.).
Anyone have any suggestions??
Lexus letting us down
Appreciate the update. What is Lexus’ next step? This sounds like a case where they need to buy the vehicle back from you. I know 2 other members had theirs purchased back. Is that option for you?
It is an option and they opened that avenue for me to pursue, however I don’t want to part ways because there’s not a replacement vehicle made that checks all these boxes. It’s amazing except for this one small issue. Sure there are little things they could have. done better like add rear a/c vents in the OT+, more cubby’s for storage etc. the HVAC is poor in my opinion, the awkward transmission clunk when shifting from park but these are all adaptable and easily forgotten about after 3 months. This shake and their blind eye approach to run it down is unacceptable and uncharacteristicly evil behavior of Lexus
Man I feel your pain. I’d be frustrated as heck if I were in your shoes. I’m just praying that when I get my 2025 OT+ that it won’t have this issue. Spoke with my sales rep just last week and she said she hadn’t heard of the vibration issue. My dealership has delivered about 30 OT’s to date. She has heard about the squeaky brakes though.
Mine doesn’t have the shaking, but it has developed the brake squeal after 6500 miles.
When I took it in for 5000 mile service, i spoke to the service manager about all the problems I have read on the forum. I told him the brake squealing was intermittent, and he shockingly assured me that it would get worse, and he went ahead and ordered the replacement parts.
I asked him if he’d seen any 550’s with the vibration issue, and he shot straight and said he’d had a few come in for that.
He told me that whatever problems I read on the forums, they know about them well in advance. The service manager straight up told me that part of the problem is that they need to wait to hear from Lexus on how they want certain issues fixed to cover the dealerships ass. He acknowledged my hood flutter as well. He told me the adhesive delaminates from what supports it and that they are waiting for the “official” fix from Lexus on that as well. Awesome dude, but am for sure waiting til the official lexus fixes come down the pike so it can be done the right way
Update
I’ve been building and revalving (shim stacks) for over 20 years on motorcycle shocks/forks. Done a handful Fox shocks for trucks as well. What your proposing might be true. Have your buddy look at the opposite left side rear in the hopes it’s not bouncing. Swap the two rears and test again. Also, try reaching out Bilstein, Ikon, OME (Old Man Emu). They will have a replacement soon.
