I received this very useful response from FITCAMX today:@Zaki6 Yes, I've found that to be the case as well. For some reason I don't quite understand, the GX550 has to connect to the FITCAMX as WiFi and that action doesn't allow the GX550 to load CarPlay via Bluetooth. However, if you plug your phone in via USB cable you can have both the FITCAMX camera and CarPlay, so that's what I do now.
I also thought that since I didn't renew my vehicle based AT&T WiFi service, that may have been the issue, but no. I renewed that AT&T service and the GX still can't load CarPlay without the USB cord while the camera is functioning. Can someone explain why that is to me?
Thanks, @Zaki6. That's essentially what our friend @klautoGX550 has been telling me, but it's taken a while to sink into my thick skullI received this very useful response from FITCAMX today:
What happen ? Are you going with a different dash cam ?not the place for sales but, someone interested might be reading the thread so.....I have a unit to sell I decided not to install. BNIB If anyone is looking
no. Just decided I didn't need itWhat happen ? Are you going with a different dash cam ?
Not sure if anyone did the parking mode on the install , we only use the plug and play for Ignition ON recording only.I got my dash cam finally installed. I got a few issues ...
I modified the plug and play harness to use the hardwire kit so I have the parking mode. Does anyone have parking mode setup? I noticed that it is saving files in the locked folder. It might be due to the way I wired that parking wire, just need someone to confirm for me.
I pressed the snapshot button while witnessing a near miss in front of me. I figured I would mark the timestamp of that picture and then find the video ... However there was nothing saved and recorded during that time. It was the only time missing during a 4hr drive. Can someone test that out?
The CarPlay not connecting is extremely annoying. I read everything in the thread prior and understand you can't leave the camera wifi on auto-join. Every time I try to connect my phone through the car, it says car play error. I had to fully disconnect the phone and add it as a new device. I'm sure the next time I connect to the camera it will give me the same issues again.
Sounds goodI emailed Fitcam and they confirmed that parking videos will be saved in the locked folder. Not sure why they included a parking folder if it never gets used. I will do some more test of the videos and post a video of how I modified the harness to make everything work and wired from the mirror area.
That’s not exactly what they are saying. You just can’t have both connected at once. So connect to camera, get it setup like you want and then tell you phone to forget that WiFi device. If you ever need to look at a video for some reason you can pull the SD card or connect your phone again and download the video and then tell phone to forget the device.So from what I am gathering from the Fitmax cam is that wireless carplay really does not work with the camera installed.
You would have to use carplay with physically plugging the phone in, correct?
TIA
Here you go guys hopefully this helps on how to install the rear camera , remember to use my discount code : save10withk1 for 10% off + free shipping
One suggestion @BriC-622, I K1autogx550 shows in his video that the wire between the rear and front camera is too long, so it has a lot of slack. I found that putting that extra slack wire above either of the two passenger side doors was challenging, as there seemed to be a lot of vehicle wiring in the roof (airbags?) so I found that stuffing all that extra wire slack into the headliner above the rear window (IMG_4709) was pretty easy. Clear as mud?This is SUPER helpful..
