Westcott Leveling Kit and 35s
As promised side pic
. Hope this is the angle you wanted to see
Has anyone seen a leveling kit that only brings up the nose of the car and not the 0.75" in the rear? I want the Westcott Lift, but concerned with the roof and my garage height.
I added a peak suspension front spacer kit for an added 1.25” up front. Rear is stock. Brings up the front, still still has a slight forward rake and
Amazing, didn't know that was an option. Does it change the drive at all? In the image, the front actually looks a bit higher than the rear, but maybe it's just the photo. Any other pics? Where did you have it done?
That was a photo on uneven terrain. Here is one on level ground. The center of the wheel to fender measurement is still higher in the rear by an inch.
Nothing noticeable on the street. Not recommended for heavy off-road use. Should be fine for trails. I had a local tire shop install it. It’s a quick install since the shock assembly doesn’t need to get taken apart
