I wonder how they got the fox suspension components to fit. I haven't seen them available for this platform.37's with Fox lift and 17" Methods with +25 offset and NYTOP front bumper and sliders...
Lexus GX550 Overtrail Build by Bink Designs
Per Lexus service center, its 96 ft-lb for my overtrail model, but seems like same for all models.GX 550 need M14x1.5 lugs, correct? Same as Landcruiser.
And torque spec is 97 ft-lb? Please confirm.
Thanks!
yes...that combo is 33". because of avail offsets from Vossen, you just need to be ok with the wheel/tire poking out more than stockWould these fit premium plus? Pick up mine last week. White with blackout emblems and want totally black rims.
I suspect this truck is one of the test fit rigs.I wonder how they got the fox suspension components to fit. I haven't seen them available for this platform.
What's the offset on those wheels? Assuming no other modifications needed to fit those tires?Nice! Just got the 20 x 9 Niche Vice wheels on mine with 275/55R20XL Toyo Open Country AT III's
My HF6-4 are on order and will be going with 275/60/20 or 285/60/20
Thanks, thinking of running a similar setup. What did you use for the front lift?it's 33.5", it'll be close but I have a 1.25" lift in the front already. I'm leaning towards the 275/60/20 for an even 33" and no risk of problems.
Not too many threads with a tire in that size....but there were a few on the LC forum that had no issues.
Peak suspension spacer lift - 1.25". Spacer lift that didn't require cutting anythingThanks, thinking of running a similar setup. What did you use for the front lift?
Nice! I really like the wheels. I would probably have gone with 50 series for more sidewall. How do you like the ride?
Thanksyes...that combo is 33". because of avail offsets from Vossen, you just need to be ok with the wheel/tire poking out more than stock
